Согласна
Однако 12 часов это не 6 часов...
Нужно самой наверное поэкспериментировать
Так впишу еще один пункт в список требований к потенциальному работодателю - наличие холодильника
After immersing the wallet in cold water for the appropriate length of time, the crystals that are contained in the Panels expand into a gel. Once the crystals turn into the gel substance the evaporation process begins. This occurs when air reacts with the gel creating the cooling effect. Due to the gel reacting to air, it is vital that the wallet must be in contact with air, to enable it to Breathe and must not be placed in any air tight container/bag.
После "зарядки" работает минимум 45 часов при внешней температуре 38,8 гр.Once the wallets have been immersed in water for the correct amount of time, they will have the ability to keep insulin cool for a period of a minimum 45 hours (Based on a constant environmental temperature of 38.8 °C (100 °F)
Кошелек держит температуру 18-26 град. Цельс. в зависимости от климата. При температуре 38,8 гр. максимальная температура будет 26 гр в течении 45 часов.The wallets keep insulin cool between 18-26 °C depending on the climate which the wallet is exposed to. For example, if the wallet was in a constant climate temperature of 38.8 °C (100 °F) then the wallet will keep the insulin cool at 26 °C for a minimum of 45 hours.
Does it prevent insulin from freezing?
All we can say, is that the wallets have been used by professional mountaineers in extreme conditions, and they have said the FRIO prevented the insulin from freezing during their trips, please see the section "What customers Say"
