Болезнь Альцгеймера - это диабет?
Что нового? Обсуждаем.
Болезнь Альцгеймера - ещё одно осложнение диабета 2 типа?
Сообщение opb0101 » 22 июл 2006, 23:20
Another Complication from Diabetes: Alzheimer's Disease
www.medicalnewstoday.com/medicalnews.php?newsid=4531 - 47k - Jul 20, 2006
Epidemiologists have long noted that there appears to be some sort of correlation between type 2 diabetes — the type that's associated with obesity, and which often appears later in life — and Alzheimer's disease. Now a number of brand-new studies, presented at a major Alzheimer's conference in Madrid, has strengthened that link. In one, Swedish researchers looked at 1,173 people over 75 and concluded that people with borderline type 2 diabetes — that is, chronically elevated blood sugar — were about 70% likelier to develop Alzheimer's than those with normal sugar levels. Another study, based in the U.S., looked at the medical records of 22,852 type 2 diabetics, none of whom had any sort of dementia at the outset, and found that the more elevated their blood sugar tended to be, the bigger the risk they'd develop Alzheimer's. Several other studies hinted, though did not prove, that a class of anti-diabetes drugs called glitazones may lower Alzheimer's risk.
It's still not clear why diabetes and Alzheimer's should be related. One possibility is that the excess insulin the body churns out to try and control blood sugar inflames the blood vessels — which would also explain how diabetes leads to heart disease. But while it isn't yet exactly certain what's going on, the result is a kind of good news/bad news story. The bad news is that type 2 diabetes has been on a dramatic increase as Americans have gotten more obese over the past couple of decades — which means the Alzheimer's epidemic that's already expected simply as a result of the aging of the massive Baby Boom generation could be even bigger than anyone thought. The good news is that by inching closer to an understanding of precisely what it is that causes Alzheimer's — or even getting closer to one possible cause — doctors may be able to stave off the disease.
Коротко :
Выявлены зависимость между диабетом2 и Alzheimer's (у 70% из находившихся под наблюдением 1173 человек старше 75 лет (это радует! :D ) с диабетом2 и хронически повышенным уровнем сахара в крови развилась болезнь Алзаймера. Анализ 22852 медицинских записей, проведенный американцами, показал, что чем выше уровень сахара в крови, тем выше вероятность заболевания. Природа связи диабета и болезни Алзаймера пока не изучена, вероятнее всего, причина в воспалительных процессах в сосудах, аналогичных тем, которые вызывают поражение сердечно-сосудистой системы. Предположительно, анти-диабетические препараты - glitazonы снижают риск заболевания.
Интересно, почему рассматривался только тип2 - или мы, которые с типом1, просто не доживаем? Или постоянные занятия арифметикой спасает? Пишут, что постоянное умственное напряжение снижают риск
:подумай
Olga
opb0101
Сообщение Элли » 23 июл 2006, 20:58
Заболеваний - предпосылок к "Альцгеймеру" на самом деле, возможно, гораздо больше - вряд ли они сводятся к одному диабету...
Елена
Поживем - не то еще увидим
Элли
Сообщение Фантик » 12 сен 2014, 08:16
Когда первые новости о том, что между болезнью Альцгеймера и сахарным диабетом есть много общего, впервые появились в 2005 году, многим казалось, что это очередная журналистская утка. Однако накопленные к настоящему времени данные однозначно показывают, что болезнь Альцгеймера является сахарным диабетом особого типа, который предложено называть СД 3 типа.
При болезни Альцгеймера белок бета-амилоид, образующий бляшки, замещает собой нормальные клетки мозга, вызывая классические симптомы болезни Альцгеймера: потерю ориентации, памяти, утрату личности. Механизм формирования этих бляшек был неизвестен до начала 2000 годов, когда невропатолог Университета Брауна доктор Сюзанна де ла Монте начала эксперименты по блокаде инсулинового пути в мозге экспериментальных животных. Ей удалось обнаружить, что такая блокада вызывала у животных симптомы болезни Альцгеймера. Вывод, сделанный доктором, связывал недостаток инсулина с формированием бляшек. Другими словами, развитие болезни Альцгеймера является формой диабета со специфическими мозговыми проявлениями.
Инсулинорезистентность, обычно присущая СД2, эквивалентна в случае болезни Альцгеймера недостатку инсулина. Поскольку мы знаем, что одной из причин СД2 является неправильное питание, то можно предположить, что при болезни Альцгеймера диета, подобная рекомендуемой при СД2, может давать определённый эффект.
Также при СД2 существует связь с развитием диабетической нейропатии, заболевания, медленно разрушающего нервные ткани посредством индуцированного глюкозой воспаления. Можно предположить, что при СД2 повышен риск повреждения тканей спинного мозга и головного мозга, и, возможно, развитие болезни Альцгеймера также может быть связано с наличием СД2.
Эти предположения необходимо подтверждать соответствующими клиническими исследованиями.
АНГЕЛ (12 сен 2014, 08:55) • KRONa (12 сен 2014, 10:22) • Кокоша (12 сен 2014, 11:10) • Лисичка25 (13 сен 2014, 11:33)
Re: Болезнь Альцгеймера - это диабет?
Сообщение Березка » 19 мар 2016, 12:44
Фантик, видимо, можно дополнить твою цитату "Жизнь делится на три этапа — сначала нет ума, потом здоровья, а потом ни ума, ни здоровья."
За это сообщение автора Березка поблагодарили: 2
SD-1 (19 мар 2016, 13:32) • Skywalker (10 май 2017, 22:31)
Березка
Сообщение АлексКокс » 19 мар 2016, 14:25
А энцефалопатии вам разве недостаточно ? Диабетической + сосудистой . Вом вам и болезнь Альцгеймера
АлексКокс
Сообщение Juris » 19 мар 2016, 15:12
В случае сахарного диабета этот этап очень часто бывает не потом, а до того :плачу
АлексКокс (19 мар 2016, 15:13) • Mishlen (19 мар 2016, 22:08)
